08-04-2020 08:00 AM
So I know that if you import a DBC into an XNet Database, that you can use the Get DBC Attribute to get the signal enumeration and values. But what I'm trying to figure out is if there is a way to create a signal dynamically with the Database Create Signal, and then set the enumeration, with these value string pairs.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
08-27-2020 08:33 AM
So...anyone? How can I set enum signal values?
09-08-2020 10:56 AM
Not that I can see, unless you create an in-memory database, then merge them with "XNET Database Merge", and merge either clusters or frames
