08-01-2008 03:17 PM
The product of our project will be a LabView subroutine that would take in a list of messages and output the responses to those messages. A named cluster might be an appropriate format for the output. The subroutine should be generic in that once it is fed the appropriate message(s), it can query across the CAN to the appropriate sensor. We need this capability because many new sensors that we use for testing come only with CAN outputs rather than the traditional voltage outputs. These are relatively simple transducers that don't have extensive vocabularies. Six messages may be sufficient for each of these applications.
CAN subroutine suggestions:
-six message (word?) capability These messages can be fed in as inputs specific to the particular transducer the routine to be used.
-named cluster output
-should be able to run in a 20 hz main loop if possible
**In order to proceed with this project, we need communication between the sensor and the bus, which is our main problem. When using MAX, we only get error transmission with a 100% bus load, does this means the sensor is actually working? Also, does anyone knows how to insert the sensor as a LV subroutine, once is communicating?
Thank you!
08-04-2008 02:36 PM
08-04-2008 03:36 PM
08-05-2008 08:13 AM
08-05-2008 03:28 PM
08-05-2008 04:35 PM
Ay suggestions? Thanks!!!
08-07-2008 10:04 AM
08-07-2008 04:02 PM
08-08-2008 12:01 PM
08-08-2008 05:21 PM
