05-11-2006 05:42 AM
05-11-2006 08:15 AM
Hi developer...
It would be helpful if you could specify which Software and hardware are you using to do this. If it is NI Hard- and Software it should be easy.
Write the message to the ECU with a simple write net and then use a while loop with wait for state to wait for this 4 message. The wait will block the thread until all four message arrive and you can read them immediately using a read mult net after the wait.
DirkW
05-11-2006 08:46 AM
hello DirkW
thanks for ur reply
I am using NI PCMCIA Series II CAN card and LabVIEW 7.1 software
i tried but some frames are missing,
i attached my program, please give me an idea how to do it.
thanks
sk
05-11-2006 09:03 AM
hai
Is it possible to monitor the CAN data transmit/receive , time & id etc., using two NI PCMCIA CAN card. in my Notebook
thanks
sasi
05-11-2006 08:11 PM
hello
i tried, but some frames are missing,
i attached my program, the sequence where i colored green is where i am reading frames.
thanks
sk
05-11-2006 10:00 PM
hello
thanks
sk
05-12-2006 08:36 AM
as posted in one of your similar threads here is an example for reading 4 or more consecutive frames.
And change your programming style to have config and open and close only once outsite your main while loop.
DirkW
