Automotive and Embedded Networks
Read CAN Data message With more Than 64 bits
Dear All,
I'm working With CAN card PCI Series 2 with Labview 8.2.1 and Measurement and automation 5.1.
I'm making measures from an ECU.
This one (please see piture) is composed with more than 64 bits for one ID.
I don't found how I can read those Data using "Channel API". Is It possible ?
On MAX I am not able to creat CAN Task measure with more Than 64 bits...
It is necessary to use only "Frame API".
Thanks for repply.
(6,406 Views)
Accepted by __KB__
NI-CAN Channel API is not able to deal with Multi frame messages, so you would need to use the NI-CAN Frame API to read the Multi frame message and do the conversion into physical values on your own.
(6,403 Views)
Thanks for repply.
(6,396 Views)
