01-06-2026 07:16 PM
I would like to build RPM reader with pulse output like this product: https://www.imc-tm.de/fileadmin/Public/Downloads/Manuals/imc_Telemetry/Abgekuendigte_Produkte/RPM-80...
I wonder if the NI USB-8502 that has Sync I/O port (T0 or T1) can be used to generate pulse output?
Based on the NI USB-8502 specifications it stated:
Sync Port:
I/O compatibility |
5V TTL compatible |
Number of generic triggers[2] |
2 |
Supported Input Time base frequencies |
1 MHz, 10 MHz, and 20 MHz with auto detection |
Supported Output Time base frequency |
1 MHz |
01-06-2026 08:19 PM
According to NI-XNET User Manual
USB-850 x 2-port devices can also generate a clock of 1 MHz, allowing for accurate CAN-CAN, CAN-LIN, and LIN-LIN synchronization.
01-08-2026 05:09 PM
Thank you for your reply @ZYOng
Is it also possible to generate customize pulse output in different frequency and duty cycle just like another NI digital output device?
01-08-2026 06:48 PM
To my knowledge, not possible.
