01-31-2007 06:05 PM
02-01-2007 09:52 AM
02-02-2007 01:02 PM
The function is working but I have one more question
START OUTPUT
Transceiver Mode: SLEEP
02/02/2007 12:56:13.193 ArbId 100 00 00 00 00 00 00 00 00
02/02/2007 12:56:13.600 ArbId 101 fd 02 10 04 aa aa aa aa
02/02/2007 12:56:14.222 ArbId 25d 02 1a c2 00 00 00 00 00
END OUTPUT
I am looking for a response 65d xx xx xx xx xx xx xx xx
Will the Rx set to CAN0 pick this up or do I need to somehow configure the Rx to look for 0x65d ?
ThankYou
02-02-2007 02:45 PM
I am still trying to trap a response from the module.
I hooked up an o-scope to monitor traffic.
My Wakeup should be at a higher amplitude to wakeup the bus.
The signal is at the same amplitude as all other communication.
What did I miss on the setup?
02-02-2007 05:28 PM
02-06-2007 12:28 PM
Hey Rich,
You would need to configure you Can device to what information you are looking at. I'm not sure if you had a chance to look at this start-up tutorial, but it explains the process of getting up and started with NI-Can.
Good luck!
Nick D.
04-18-2013 10:31 AM
can you please check if this vi's works for you
04-18-2013 12:16 PM
Hello Rgomez.
The last post was 2007...
I have had this working for many years...
But thank You for responding.
I do appriciate feedback.
04-18-2013 02:05 PM
Can you share your code? I would like to use XNET and replace the CAN vi's
04-19-2013 02:22 PM
I am sorry, the library is licensed to Aeroflex. You can look them up on the web. But it is developed for the test systems and uses a unique language called Marconi Test Language.
