PCAN USB for simulating CAN environment
I would like to Simulate a CAN environment without actual CAN node.
I would like to connect a PCAN USB which is connected to PC to other PCAN USB which is connected to Other PC i.e. I would like to establish a communication between two PCs using two PCAN Usb connecting each other.
Is it possible to connect two PCAN USB interface and simulate a CAN system?
I request to help regarding this.
Message 1 of 11
(10,640 Views)
Hey,
i guess it is possible. But i think it is kind of complicated.. why not just using Ethernet ?
However, if you wanna do this i think you have to implement the drivers of the PCAN USB device.
Message 2 of 11
(10,620 Views)
Hi Markus,
Thanks for the replay.
I connected the PCAN USB interfaces and simulated a CAN environment.
I used PCAN USB because this is device we use to monitor CAN node in real set up.
Now simulated environment is working fine in which PC is acting like a real CAN node.
Regards
Suresh
Message 3 of 11
(10,618 Views)
Ah..Great. So your isse is kind of fixed.. ?
Message 4 of 11
(10,613 Views)
hi surya is it possible to check the device in NI measurement & explorer
Message 5 of 11
(10,250 Views)
Hi ,
NI measurement & explorer supports only NI CAN devices.
PCAN is not supported by NI.
Hence it is not possible to check this device through NI measurement and explorer.
Regards
Suresh
Message 6 of 11
(10,245 Views)
can you share some VI regarding initialising PCAN in labview & reading CAN messages
i wll be very thankful to u
Message 7 of 11
(10,226 Views)
HI,
PCAN is not an NI supported Hardware.So i think its is not possible to configure it through Labview.
I didnt used Labview for my set up.I used PCAN view.This application software is supplied by PCAN user interface vendor(Peak systems).Through this you can configure the PCAN hardware,send and receive messages.
Message 8 of 11
(10,201 Views)
i had built the VI & its working  thks for reply
Message 9 of 11
(10,185 Views)
oh...thats great!!
Message 10 of 11
(10,172 Views)
