Automotive and Embedded Networks
NI-xNET CAN interface Queued/Single Point/Stream
Hi guys, I want to write a known frame on the Bus 1 time an directly after want to read a frame with a known Identifier. But only that frame, so no other received frames in that time.
What is the best way or only way?
(7,170 Views)
I found out its best to use a Queued session with an Eventframe. I specified a cluster and a frame in the database editor but I cant see how to fit in the termination? I tried to put the termination afterwards in the 'session node' but this give me an error 'The session is already started, impossible to add the termination now'.
How can I add the termination in the database?
(7,150 Views)
you cannot set termination in the Cluster of the database. This is a Session property you need to set before you start the session or the first Read/Write call.
So do CreateSession, then set the Termination then Start the Session. If you need an example let me know
(7,148 Views)
Hi Gibson, yez, a sample will be helpful. Great Tnx!
(7,146 Views)
Accepted by topic author JoVMo
Example: Single Point In Session with Termination Set ON
(7,139 Views)
