Automotive and Embedded Networks
NI XNET SecOC module from autosar projects
I am involved in a automotive project that use AUTOSAR standards and the communication on CAN is stored in arxml files. Also has implemented the SecOC (Specification of Secure Onboard Communication).
When loading the arxml file in the editor the frames wich use SecOC are not visible.
I am using the X-NET version 18. It there a implementation to use the arxml database with SecOC with NI XNET?
(1,113 Views)
SecOC is supported with AKKA's PROVEtech:RBS Toolkit.
PROVEtech:RBS - Base and CAN/​CAN-​FD for LabVIEW
PROVEtech:RBS - Base and CAN/​CAN-​FD for Veristand
After you install the toolkit for VeriStand, from the manual in C:\Users\Public\Documents\National Instruments\NI VeriStand 2020\Custom Devices\AKKA\PROVEtechRBS\Windows\Documentation, you can get more details about SecOC in section 2.1.4 SECURE ONBOARD COMMUNICATION
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(1,088 Views)
