Automotive and Embedded Networks
NI CAN9853
Hi everyone,
Am working on an electric vehicle control unit using CompactRio and am using the NICAN9853 module, am wondering how i can use CAN0 interface for both transmit and receive. I have designed separate VIs for transmit and receive but i cant seem to get a way how i can integrate them to create a tranceiver via CAN0 interface.
(6,226 Views)
not quite sure were your problems are, but e.g. if you look on the example CAN Basic(FPGA).vi you can set the IO Node to reveive frames as on CAN0 and to Transmit Frames on CAN0. just select within the Receive IO NOde CAN/NI 9853/CAN0
(6,224 Views)
