Yes, I went through that explicit messaging example and even the set attributes example.
In that example, I set the Service Code to 10 (Set Attribute) instead of E (Get Attribute), and made sure the Data Length was set according to spec for this attribute, is this correct?
What does it mean when the response is:
Service Code: 14
Data: 15 FF 00 00
Even after running the example and issuing the service codes, and sending it the data it was looking for, it did not modify the attributes (Checked in the NI-DNET Configurator).
Message Edited by gmeyer on 05-23-2006 07:51 AM
