Automotive and Embedded Networks
MELEXIS USB LIN MASTER not working under Windows 10
I've developed a lot of tools with the Melexis LabVIEW drivers, but I've noticed that they only work on windows 7 or XP.
When I try to run them on Windows 10 seems like the ActiveX objects can not be accesed or something.
Attached the drivers used and the error obtained
Anyone know how can I solve this compatibility problem?
The tools seems to work with C# and VBA but with LabVIEW something is happening T.T
Installed drivers:
HISTORY of "Melexis Development Tools incl. GCC 2.x"
Package includes following components:
- Melexis Programmmer Setup V2.21.2
- Melexis Emulator Setup V2.21.9
- Melexis MLX16 GCC V2.4.2
- Melexis LIN Commander V4.0
- Melexis LIN PSF V1.52.01
- Melexis Generic PSF V1.28
- Melexis MPT V1.31
- Melexis MPT LIN UI V1.30
- Melexis Debugger V1.16.2
- Melexis MLX16 CPU Simulator V2.61.1
- Melexis FTDI USB Driver V2.08.30
- Eclipse CDT V8.8.1
- Melexis IDE Plugin V1.1.1.201104041646
- Melexis MLX16 GCC Plugin V1.0.7
(4,275 Views)
Accepted by topic author AlexRg
Solved:
It is necessary to have the last version of the PSF drivers. Are installed from the MLX_Development_Tools_1.10.0.exe
This file can be dowloaded asking Melexis for acces to the softdist.
- Melexis Programmer Setup V2.25.0
- Melexis Emulator Setup V2.25.0
- Melexis MLX16 GCC V1.12.6
- Melexis LIN PSF V1.61.2
- Melexis MPT V1.31
- Melexis MPT LIN UI V1.34
- Melexis Debugger V1.16.4
- Melexis MLX16 CPU Simulator V2.63.2
- Melexis MLX16 GCC Plugin V1.1.0
(4,245 Views)
