Automotive and Embedded Networks
LabVIEW 2017 XNET CAN Read issue
did you find the root cause of why you are only able to read the signals with the bus monitor open?
Because I have a Labview RT 2015 based program running inside a PXI system and I am experiencing a very similar problem, in my case, if i run bus monitor only once and then stop it, then I am able to read the different signals.
Message 11 of 11
(1,336 Views)
