10-07-2019 05:39 AM
Hello All,
i have need to listen all data on LIN bus.
I created VI, that works nice if there is full frame on lin bus (ID + data).
But in case that there is sent only header frame (only ID), and there is no answer from some node, labview shows LIN BUS ERROR frame.
I decoded data packet and get ID from byte 6.
Is there is way, that labview detect only header frame, and not LIN BUS error..
Thank you.
Milan
10-14-2019 09:04 AM
Your picture is not visible, at least for me.
Which LIN interface do you use ?
Have you tried to enable the error logging ?
In the examples of LabVIEW, you will find "LIN Bus Monitor.vi" which uses the NI CAN Frame API (not NI-XNET). Have you tried it ?
