10-05-2021 03:31 AM
I was trying the Examples/Hardware Input and Output/CAN/Databases (Editing and Managing)/Editing Database with IO Control.vi code and it keeps returning a Bad reference error when trying to create new Frames.
Cluster creation works fine. Is this just me or the example is broken?
All I did was changing the database name and path in Add Objects/Cluster/New Database, added the cluster and then in Add Objects/Frame I selected the database and tried to add a frame.
If I press the Add Item Now button again, it says the frame already exists:
But if I open the database with Database Editor, the cluster is empty.
I'm using LabVIEW 2017 and NI-XNET 20.5.1.
10-05-2021 04:03 AM
If you add a second Cluster to the existing database, then the cluster selector shows actual cluster options and it works.
Or you can add manually the cluster name to the control.
