Automotive and Embedded Networks
Is it possible to run DiagOnCAN with NI-CAN driver only (without Automotive Diag Command Set)
Hi everybody,
Is it feasible to run DiagOnCan without using of Automotive Diag Command Set - only with NI-CAN driver (hardware I'm using is Low Speed Fault-Tolerant - USB8472 and NI-XNET) ?
Petko G.
(6,829 Views)
Accepted by topic author pgo
no problem to do this with your hardware and the NI-CAN Frame API.
However you have to implement Diag Services and Transport Layer on your own, which is quite a huge task.
I would recommend spending the money for Automotive Diagnostic Command Set which supports
  • NI-CAN (PCI, PXI, USB, PCMCIA)
  • NI-XNET
  • cRIO/985x targets (Pharlap and VxWorks)#
which means if you plan to port your app in the future to a different hardware target or real time target you dont need to change your appl at all.
(6,828 Views)
