Automotive and Embedded Networks
I search a VI to receive/transmit messages using a database (.dbc)
I search a VI to receive/transmit messages using a database (.dbc), even if you have a VI with transmit message using a .dbc only, I will be interessed...
I found  "channel monitor.vi" in the examples of LABVIEW but I can't use it, I don't see a message that are transmit I don't know why. I have tested that I send a message with an other tool then I put my database, I select my message, I tried all the CAN channel but I see nothing, only the name of the channel that I have aded on the monitor...
HELP:smileyindifferent:
bye
(7,925 Views)
You can import the database into MAX, unless you are using a USB device.  For the USB devices you need to find the CAN conversion library.  You can also use the bus monitor that is built into MAX.  I know for the usb devices you can click on the channel you want and select bus monitor.  I believe it is the same for the PCI cards also, and that will show you all the traffic on that channel.
Have you checked your baud rates?  Do you have proper termination on the cable?
(7,870 Views)
yes but I search a VI to use with Labviewnot with MAX
(7,856 Views)
Then do a search for the CAN Frame channel conversion library I mentioned in my post and it will allow you to do that.
(7,847 Views)
hi
i am getting error with CAN Frame channel conversion library 1.0.3 can you pls guide me
(7,260 Views)
Hi TCL,
It's better to open a new post for this new question.
Take a look to this post ther a similar error of your screanshot :smileywink:.
Message Edited by Christophe S. on 06-10-2010 01:26 PM
Christophe S.
Account Manager East of France І Certified LabVIEW Associate Developer І National Instruments France
(7,241 Views)
