11-13-2006 01:05 PM
11-14-2006 02:44 PM
Hi
You can use the virtual ports 256 and 257 to set up the attached input and output example to work virtualy. But you have to install the NI CAN driver 2.3 or later.
You can download the driver here: Current NI-CAN Version
DirkW
05-26-2011 08:11 PM
Can you use the virtual CAN channels with the Frame API?
If so, how?
Don
06-06-2011 11:10 AM
Don,
I am sorry it took so long to get in touch with you. Yes it is possible to use CAN256 and CAN257 with the Frame API. They are used just like normal interfaces.
However, there are certain limitations, which are described in Table 6-1 and 6-2 of the NI-CAN Hardware and Software Manual, which should be under Start » Program Files » National Instruments » NI-CAN. For example, CAN objects are not supported, as virtual interfaces are limited to the Network Interface.
06-14-2011 07:22 PM
Thanks Drew.
Ultimately, my customer provided me with a WriteCAN256.vi and ReadCAN257.vi that were perfect for my needs. The WriteCAN256.vi along with my NI USB 8473s allowed me to provide data collection on multiple CAN devices and to verify that my Software can handle all data types from CAN devices.
Note: My customer allowed me to share his .vi's. They are enclosed ...
Best Regards,
Don W
