07-02-2013 06:40 AM
I have a software specification documents that specifies CanBus Address for heater BIT test, control, and status. I am trying to find a way to import or create a database to use in my ESS Test Stand for the heater. I have found there is several type of databases. The three listed are FIBEX, Vector, and NI Canbus. Any suggestions on which one best to use and go forward? Basically, I have a 600 plus page work document with multiple tables for all the attributes. Thanks, Greg
07-03-2013 11:04 AM
Hi Greg,
Are you thinking about handling the information using arbitration ID's? If not, could you maybe give me a little bit of clarification on what exactly you are trying to do with your documentation/database. I would recomend using FIBEX by the way.
07-03-2013 11:37 AM
I was looking for convenient way to create a database to handle at least the addressing part of the canbus message, then I woudl decode the payload portion on my own.
There is several hundered varibles and boolean bits to potenitally monitor. This might be mute now.I finally received a Vector Database that I have imported into Labview.
07-08-2013 11:41 AM
Hi Greg,
So it sounds like you are going to go with Vector. Did you have any other questions?
