Automotive and Embedded Networks
How to create .a2l file using ECU Measurement and calibration toolkit
Dear All,
I want to create .a2l file with the help of ECU Measurement and calibration toolkit in Labview. There is no support COM/ActiveX available for ASAP2 editor (Vector). Can anyone please give some suggestion on this.
Thanks in Advance.
(5,784 Views)
The ECU MC toolkit is very powerful and can work with A2L files that have already been generated, however they must already be generated from a third-party application.
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(5,687 Views)
