Automotive and Embedded Networks
How many maximum CAN message can configure ?
How many maximum messages( each with 8 bytes) can I configure for NI CAN series 2 Interface card  at full bus load ?
Thank you.
(6,018 Views)
depends on ur CAN Module(Standard or Extended).. if it is standard 11bit(000 to 7FF) similarly for Extended (000 to 1FFFFFFF)...
(6,017 Views)
It depends on the periodicity and number of channels in a message. If you have more 10 ms(milliseconds) message ,then affordable number of messages will come down.
Check your on-board can memory. Can anyone suggest the equation of formula which relates number of messages,their periodicity and On-board memory available ?
(6,010 Views)
