12-21-2011 04:40 PM
When I call CANopen TPDO Create.vi to create TPDO objects I can only input PDO1 through PDO4. How do I work with more than four PDOs?
I see the other forum thread using an older version of CANopen, but it does not appear to directly translate into the newer NI-Industrial Communications for CANopen.
12-26-2011 10:44 PM
Hi wireman,
It should definitely be possible to use more PDOs with some configuration. What I'm curious of is what you're providing to the TPDO Create vi as its inputs, specifically the Node ID and Interface Object In?
Dave C
12-27-2011 06:01 AM
Dave,
Thanks for your reply. I'm not sure what it is you're asking. I pass in the node-ID for the slave node, which varies depending on which particular device I'm communicating with. The interface object comes from a call to CANopen Interface Create.vi for the NI 9881 I'm using. The question I have is that when I call CANopen TPDO Create.vi, how do I specify a PDO channel greatert han PDO 4? The input appears to be limited to PDO 1 through PDO 4.
-wireman
12-27-2011 04:17 PM
Hi wireman,
A good resource for CANopen is available here. That page explains that typically in the CANopen standard, there are only 4 predefined PDOs in each direction (transmit and receive). To use extra PDOs, additional configuration is required. The configuration of the predefined PDO Channels refers to the COB-ID that they are linked to by default.
According to the LabVIEW help files, the COB-ID is 'calculated' by adding the value of the PDO Channel and the Node ID, if the COB-ID is zero. However, if the COB-ID is explicitly defined, then LabVIEW will ignore the calculation provided by the Node ID and PDO Channel. So, if you need more than the four PDOs, you'll need to use the COB-ID input to differentiate which channel is being referenced.
I hope this clears some things up, and please don't hesitate to ask for more advice.
-Dave C
12-28-2011 05:50 AM
Dave,
Thanks. We have already configured the slave device to send more than four PDOs, but what I do not understand is how to program the master device in LabVIEW to make the master read more than four PDOs. Can you help me with that?
-wireman
12-29-2011 04:31 PM
Hi wireman,
What did you do to configure the slave to send more than four PDOs? I think that will be key to whether or not this can be done and what steps will need to be taken to complete this job. I'm also wondering how many PDOs you're needing to use for this device?
-Dave C
12-30-2011 07:19 AM
Dave,
The slave is not implemented with NI equipment, nor is it written in LabVIEW. But to answer your question, the CANopen EDS (Electronic Data Sheet) and Object Dictionary on the slave device are configured to output more than four PDOs. (Six in this case).
-wireman
01-03-2012 10:03 AM
Hi wireman,
So I've seen a reply now from an R&D rep regarding this. He's said that using the COB-ID entry as I suggested above is the method to use to use more than four PDOs. That ID should route to an address in the device's Object Dictionary, which sounds like a known location since the slave is configured for more outputs already. Point the COB-ID at the address you've configured for the output and see if we can establish communication.
-Dave C
