Automotive and Embedded Networks
How Stop periodic Frame NI-XNET / CAN
hello
I would like to stop a perioc frame :
So i use this configuration :
":trigger:.CANCyclicFrame1" with value 0 for stop the writting of this frame
When i do this , i can update signal into this frame BUT bus monitor still  receive the frame
What i need to do for stop this frame
Thanks You
(1,155 Views)
Hi Lunik,
I think this is what you are looking for?
Re: Disable/Enable Specific Frame On The Fly w/ Signal Output Single-point
Senior Technical Support Engineer | CLD CTA | NI
DISCLAIMER: The attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for use in hazardous environments. You assume all risks for use of the Code and use of the Code is subject to the Sample Code License Terms which can be found at: http://ni.com/samplecodelicense
(1,138 Views)
