Automotive and Embedded Networks
Hi, I am using USB 8476s to communicate to a slave unit in LIN network using LabVIEW7.1. Can anyone tell me how i can send a header file plus 1 byte of data to the slave in a LIN network. or how do i use ldf file. i want to read responses from the slave.
Hi,   I am using USB 8476s to communicate to a slave unit in LIN network. Can anyone tell me how i can send a header frame plus 1 byte of data to the slave in a LIN network. or how do I communictae with slave using LabVIEW7.1.
I want to read responses from the slave. When i tried with labview exapmle programs or even using MAX also, while doing some switching action in my slave, i am getting response as Device inactive with timestamp but there is no data format.
And I have Lin Description File. Can you suggest me how to use ldf file.
I am at customer place and It would be great help from you if you can suggest me at the earliest. Thank you
(6,006 Views)
