09-06-2008 05:54 AM
Hi ,
I am using NI PCI-CAN/2 Series 2 for validation purpose . Can i use same hardware(i.e. PCI CAN CARD) for testing the GMLAN protocol.
Thks in advance
HKT
09-08-2008 08:41 AM
09-09-2008 07:18 AM
Hi DriKW,
link you have provided is not working here , can you share the content of the link .
there is one more question :-
Can we pragmatically select the Low speed(33.33kbps, single wire) mode in PCI CAN series 2 card ?
Thks in advance
HKT
09-09-2008 02:32 PM
Ups that was the wrong Link:
GMLAN is based on the CAN architecture so technically it should work with NI-CAN hardware. The reason why we cannot say it is supported is because in order to have a hardware that is GMLAN compliant, it must be certified by GM. Since there hasn't been a considerable number of customers who request this support, we have not made that yet.
Second question: Only the 8464/XS board allows to switch transceivers programaticaly to Single Wire CAN. Our High Speed boards are limited to 40 KBaud minimum.
DirkW
09-16-2008 09:00 PM
Hi. Lab V,
I am also interested in working with the GMLAN Protocol with the NI Card. I'm a novice and maybe you can guide me along. Thanks
01-10-2011 03:13 AM
Any suggestions on how to enquire PID status via GMLAN will be appreciated. I have an X-NET card and a GMLAN supported ECU.
