Automotive and Embedded Networks
Extract SPN for a signal from a .dbc using XNET API
This morning I looked at using XNET to load a CAN bus (J1939) .dbc file where I would parse frames, signals, signal SPNs, and misc signal details. I was successful except I just can't figure out how to extract the SPN for a signal. Seems like I am just a few clicks away but I'm having no luck.
Any one have an idea how this is done?
Todd
(3,297 Views)
Hello Labviewman,
Please check this thread.
https://forums.ni.com/t5/LabVIEW/Diagnostic-Messages-J1939/td-p/2157174
Diego H
(3,224 Views)
Thanks, but that doesn't help.
(3,210 Views)
Unfortunately J1939 with XNET does not currently offer the capability to extract the SPN from the signal information contained in the database.
Jeff L
(3,201 Views)
Since it doesn't look like this is possible via the XNET API, I figured out the .dbc database structure for the SPNs (signal names).
The line I look for is structured like this:
BA_ "SPN" SIG_ XXXX SPNname SPNNumber;
I look for '"SPN" SIG_' and parse the rest (XXXX is a cross reference to the PGN/message name).  If no error, I add the SPNname and SPNNumber to the 'SPN found' arrays.  Then, since I already know the SPNnames for the signals in the database via the XNET Database vis, I search the created array (SPN name found array), take the index to the found name and index the SPNNumber array for the SPN/signal number.
The above method found 97% of the SPN numbers for the SPNnames found with the XNET database vis.  I checked about 10 of the 3% that were not found...they didn't have a SPN/signal number, so it seems my method works.
(3,183 Views)
