03-05-2014 03:18 AM
We are trying to connect to an external engine using Labview CAN.
Whenever running this program we get Error 0xbff62002 approximately once every 2 minutes.
The versions that we are using are:
Labview 2011
CAN 2.5.2.
Attached is the error report.
Can anyone suggest a solution for this problem?
03-11-2014 09:38 AM
Hello Sailsim,
Have you already read through the following Knowledge Base?
http://digital.ni.com/public.nsf/allkb/25A1726C45E10F48862568F700715733?OpenDocument
Which driver version are you using?
Does resetting the card make a difference?
