Automotive and Embedded Networks
Empty ID log from NI-CAN BusMonitor
I am using NI-CAN BusMonitor with a NI USB-8473 to monitor can traffic on my system. The USB CAN is only used for monitoring not part of the system. When I run NI-CAN BusMonitor, I see one line per ArbID and I observe the number of messages incrementing for each Arb ID. But if I try to double click the id while the capture is running, I do not get the ID Log display. If I stop the capture and then double click the Arb ID, the log displays, but it is empty.
I have read the help and it appears that I should see something.
Oh yes I have logging going to a file and the file has all the messages in it, just can't figure out how to properly use the ID log feature.
What am I doing wrong?
(5,592 Views)
Hi, have you seen this article? I hope this helps
Alejandro C. | National Instruments
(5,574 Views)
