Thanks to you both.
So the hardware based counter and CRC calculation scripts will not work with Frame Output Queued mode then?
I need to provide the ability to ramp signal values up and down (at the same time as a hardware message tick and CRC)...or any sequence of signal values that go out on a per Frame transmit
