Custom Baud Rate Calculator VI?
Sorry I'm not sure. The NI Employee that posted here would be best to answer that.  But they haven't been active on the forums for years.
Message 11 of 13
(469 Views)
What is not complete about it? What are you expecting to see that isn't there? (not having looked at that VI in probably 8 years or so, I would expect it to be complete, but when I first wrote it, I believe it only supported 32-bits and was under a different CAN-FD standard as it hadn't been absorbed by ISO yet).
Message 12 of 13
(467 Views)
it's because the proposed 64 bits custbaudrate proposed by NI in XNET bus monitor is not in the putput list af the VI...  it's a pity NI doesn't share the code behind this cut baudrate calculator, it would permit any application to use the good one depending on hardware.
Francis M
Message 13 of 13
(442 Views)
