01-30-2018 06:03 AM
I want to use a power supply plug for pin Vsub (9V-30V).
The power plug has 12V / 300mA. Is this enough for the NI9862 module in a cDAQ 9171 frame?
I cannot test it because the test station will be build up later.
01-30-2018 08:50 AM
The manual for the 9862 states the power draw from the chassis, and the chassis states the maximum power draw from USB. But I also couldn't find in the manual where it stated the power draw from the VSup. I know that it isn't much. I ran a 4 slot embedded chassis running RT Linux, and one of these cards with a 500mA 12V supply. The chassis likely would draw more than that under full load but it worked for a bench setup. NI should chime in but I'd bet 300mA is enough for just the CAN card.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
01-30-2018 03:56 PM
During normal operation @ 9V the 9862 will typically sink around 30mA with a theoretical maximum surge of 105 mA.
