09-20-2017 10:51 AM
Hi.
I'm using my laptop with LabView 2016 and a USB-8502 with NI-XNET driver 17.0.1f0.
I want to read and write frames on a CAN bus, but a I have a question about if I can create un VI that it runs in real time, since the USB-8502 has support for LabView RT.
¿The VI deploy within USB-8502? or ¿Is it necessary to have a RT target?
Thanks very much for the help.
Solved! Go to Solution.
09-20-2017 11:00 AM
The VI does not run on the USB-8502 so to have an RT application the USB-8502 would need to be connected to a Real Time host/target.
09-21-2017 09:36 AM
Thanks you, Jeff L.
Your answer was the one I was expecting.
I appreciate your cooperation.
