Automotive and Embedded Networks
Could I create RT applications using only USB-8502?
Hi.
I'm using my laptop with LabView 2016 and a USB-8502 with NI-XNET driver 17.0.1f0.
I want to read and write frames on a CAN bus, but a I have a question about if I can create un VI that it runs in real time, since the USB-8502 has support for LabView RT.
¿The VI deploy within USB-8502? or ¿Is it necessary to have a RT target?
Thanks very much for the help.
(2,906 Views)
Accepted by topic author SergeyGM
The VI does not run on the USB-8502 so to have an RT application the USB-8502 would need to be connected to a Real Time host/target.
Jeff L
(2,899 Views)
Thanks you, Jeff L.
Your answer was the one I was expecting.
I appreciate your cooperation.
(2,876 Views)
