10-06-2017 06:58 AM
As in the subject.
What is the easiest way I can read cdd (Vector Candela file - UDS definition for a project I have) and use it with Automotive Diagnostic Automotive Set toolkit to start toking to UDS services in my DUT?
K
10-06-2017 07:39 AM - edited 10-06-2017 07:42 AM
So the only thing I've found over the years is this example set of code.
It works okay, but there were several places I needed to modify it to be more generic. I didn't want to have to specify the signal names and instead just search for "Req" and "Res" and selects those for the Request and Response IDs. Even so after modifying that code I still find it to be quite slow to process a real world CDD. I'm a bit surprised the NI toolkit doesn't have functions for reading CDD files since they are so closely associated with UDS and other diagnostics. Oh I also modified it to pull out the required Baud Rate.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
