Automotive and Embedded Networks
Automotive Diagnostic Command Set USB Transfer Data Error
I updated the packages last month when we were having these discussions.  I just checked and the package on the site contains the last update that had the bug with Quit not being in the shift register.  I just checked the 2012 back saved zip and that doesn't contain all of the updates we made.  I just backsaved the installed ISO code to 2012 and updated the zip, it should be good to go again.
Message 41 of 44
(2,184 Views)
"it should be good to go again." - sounds good, thank you again for your help with this, Hoovah!
Because of your work (and the work done by the person who created some of the Vector vis originally; forgot his name) I got my project completed on time. I could definitely not have done it without your 15765 and the other Vector vis.
Message 42 of 44
(2,169 Views)
Hi Guys,
I downloaded the back saved 2012 files and I am getting some errors. Here's one:
Hoping somebody can help. I'm using LabVIEW 2012 (not SP1).
Message 43 of 44
(1,992 Views)
At some point the Clear Errors function was improved to allow for filtering a specific error and not just all.  And if that specific error was found it would clear it and return a boolean stating if the error had been cleared.
Message 44 of 44
(1,987 Views)
