I couldn't find the answer anywhere so I was wondering if I could use the DAQ Assistant block with my NI-9862 module. If not, I will use the XNET library.
The 9862 is not a DAQ card, so it doesn't work with DAQmx, and doesn't work with the DAQ Assistant. Look up various XNet examples and you should get an idea of how to use the hardware. They are in Help >> Find Examples.
