I love being able to simulate DAQ hardware and write the program before ever connecting the hardware to actual instruments, but the default waveform that is generated from a simulated device is not always a great representation of the expected signal of the actual hardware. Right now I have to program in a way to select between signals from the simulated DAQ device using DAQmx Read or a Simulated Signal express VI. It would be great if the Simulated Signal express VI was built into MAX so that the signal from each simulated DAQ device could be modified from Max. This would simplify the LabVIEW code needed and allow me to easily test the code.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
