Additional NI Software Idea Exchange
JB
Connector of NI-CAN Frame API VIs
Status: New
Please modify the VIs from the NI-CAN Frame API library in order to use the 4x2x2x4 connector (pattern 4815) or at least a symmetrical connector.
The improved library would avoid wire bends (error cluster, ObjHandle...) and simplify the alignment of the VIs.
For example this is the current connector of ncReadObjMult.vi :
1 Comment
David_L
I agree that almost all connector panes should have the 4-2-2-4 pattern if they have error terminals and handles/references.  It makes everything much neater.  There are other ideas in this post on the same concept:
Change error terminals of Variant to Data function to match every other VI and Function in LabVIEW
