Actor Framework Discussions
"Launch Actor.vi" breaks with changes to Actor Core
Crosspost:
http://forums.ni.com/t5/LabVIEW/quot-Launch-Actor-vi-quot-breaks-with-changes-to-Actor-Core/m-p/2538...
I moved from LV2010 to LV2012 recently, and started modifying the Actor Framework template as per my application need. Here is the sequence of changes after creation of template project:
1) Create Independent Actors
2) Add extra actors, and assign proper inheritance
3) Open and add code to the Application Launcher Actor Core VI (One which starts the entire app layers and establishes connection between them)
At step 3, I modify the code to Launch several other actors and enqueue the messages. Everything seem to work perfect, till a point that the Launch Actor.vi become broken (Shows static VI reference error) randomly.
Is there something I am doing wrong here?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(3,708 Views)
a) Can you post the exact error?
b) Look at your Error List Window. Items with red Xs next to them are direct errors. Items without red Xs are broken because they depend on something with a red X. Make sure you follow the trail until you get to something that has a red X by its name. What error do you see listed there?
(3,093 Views)
