02-01-2018 09:30 PM
I have a daq actor who does some post processing in its Stop Core override and sends the resulting data to it's caller, where it is saved to a data file.
When the caller receives the Last Ack from the daq actor it closes the data file.
The problem is that the caller is receiving the Last Ack message before the final data message sent in Stop Core and prematurely closing the data file.
Looking at Actor.vi, it seems that the message sent in Stop Core should be in the caller's queue before the Last Ack message is sent, but the Lask Ack message is being handled first...is this expected behavior?
02-01-2018 09:57 PM
Last Ack is sent at critical priority, so yes, your caller might handle it before any message it got from Stop Core (or elsewhere), even though the message from Stop Core was sent first.
Why not just bundle your post-processing calculations into your nested actor's attributes? Your caller can retrieve the results from the nested actor object in Handle Last Ack, write them to file, and then close the file.
02-02-2018 04:19 AM
Shouldn't "Last Ack" be the last message handled? It's got "last" in its name, after all. One of the reasons I don't like "priority" in a message queue is that it gets harder to reason about, but I would say that "Last Ack" should be lowest priority, so is the last handled.
02-02-2018 07:32 AM
This is what I had gone with as a solution until I could understand what was going on...but I agree with drjdpowell that it is a little counter-intuitive that the Last Ack skips to the front of the queue.
02-06-2018 11:31 AM
It is counterintuitive. It's not a conscious decision of the AF, but it is a required result of other conscious decisions. Curiously, this is the first time I recall it ever coming up. That's surprising to me now that you highlight the issue. I guess the canonical AF behavior should be "if you are an actor who will return a result to caller and then terminate, return the result within yourself, not in a separate message, and let your caller harvest it from the Last Ack."
That actually has a nice symmetry to it -- caller creates a nested actor object, populates it with the problem instructions, then launches the nested actor. The caller then gets that same actor object back in the Last Ack message.
But I agree that the arrival of message after Last Ack is counterintuitive. The reason Last Ack gets critical priority is to stop the caller from continuing to send messages to a dead address, rather than assuming they will learn about it by checking for errors on the enqueuer. But it probably isn't as clean as it should be.
Put it on the list of things to consider for AF 2.0.
02-06-2018 03:38 PM - edited 02-06-2018 03:38 PM
Priority wont reliably help you here, as you can get:
1) Caller sends Stop to Nested
2) Caller starts handling the next message
3) Nested stops and send Last Acq
4) Caller, continuing execution of the message, tries to send a message to Nested and gets an error.
The reliable choices are
A) handle no message till one handles Last Ack (i.e. Synchronous Request-Reply)
or
B) Record somehow that Nested's address is to no longer be used even if you haven't yet received Last Ack.
02-06-2018 09:44 PM
or
Even without leaving the "only send messages to callees and caller and self" paradigm, I don't think either of A or B will be sufficient. Imagine:
02-07-2018 12:21 PM
In my particular case, I realized that my caller actor would need to send a message to itself from Handle Last Ack to close the data file so it would be at the back of the queue behind any data points still waiting to be saved to file.
