Actor Framework Discussions
Message Maker and AF4.1 for LV2011
Hello, I installed AF4.1 for LV2011 (great work!) and now the message maker creates the Send method with broken arrow. Actually, I just have to replace the Enqueue VI (because of the name change in 4.1) but where could I find the code of Message Maker to make this change in a permanent way?
Thanks for your answers!
Message 1 of 9
(8,500 Views)
Accepted by topic author Ivano
I found it in:
C:\Program Files (x86)\National Instruments\LabVIEW 2011\project\Message Maker
It is easy to change the Send template to be compliant with AF4.1.
Message 2 of 9
(5,161 Views)
Would you mind uploading the patched VI to this site and then adding a link to it on the READ THIS FIRST page?
Message 3 of 9
(5,161 Views)
Better option: Post the source code for the VIP development project so someone in the community can update the packages with all necessary changes (and likely a few feature improvements, too). Having to download several .vi patches and add them manually is a real chore.
Message 4 of 9
(5,161 Views)
David: You say that as if I have any of that package up to date in a distributable form. I haven't rebuilt the message maker package at all in a while because I've been working inside LV's own source directories under Perforce. I'd be building that package from scratch.
Message 5 of 9
(5,161 Views)
So the Message Maker for LV2011 is exiled to the wasteland now that it's part of LV2012?
Message 6 of 9
(5,161 Views)
No. That's why I asked him to post the one patched up VI. It's in the same place it was before -- the community. 🙂
In all seriousness, supporting the back port or other extensions is something I want to do, but I've only got so much spare time. I'm spending work time on the AF forums these days now that AF is an official part of LV, but its development going forward remains a side project, albeit now an officially recognized side project.
Message 7 of 9
(5,161 Views)
I uploaded the source code in:
https://decibel.ni.com/content/thread/13809
Message 8 of 9
(5,161 Views)
Thank you!
Message 9 of 9
(5,161 Views)
