Actor Framework Discussions
LabVIEW 2020 "Casting Utility for Actors.vim" re PPLs
Although not really a problem, the use of "Casting Utility for Actors.vim" in the Do.vi that is scripted produces a dependency on Actor Framework.lvlib, even if the caller is using Actor Framework.lvlibp.
I'm not really sure exactly how the malleable VI works (despite the comments - sorry!) but would replacing the Actor inputs (all 3) with LabVIEW Object produce identical functionality without the additional dependency?
GCentral
(4,128 Views)
Accepted by cbutcher
Yes, that would fix it. I'll file a bug to make the change.
(4,066 Views)
Attached is the modified VI. Please give it a test.
Save into
     vi.lib\ActorFramework\Actor
overwriting the existing VI (back up first, obviously).
If y'all verify the fix works, I'll include it a future patch.
(4,046 Views)
While you are at it can it also please add a description?
I don't follow what its supposed to do either.
(4,002 Views)
Even with this fix I've been getting errors about Receive Message.vi being broken when using Actor PPLs on a Linux RT target when this vim is included in the Do.vi. If I remove the vim from the Do.vi then everything builds and deploys like it should.
I have a support ticket but curious to see if anyone else came across this or if there was a better workaround then deleting out the vim from every actor message.
(3,275 Views)
