Very entry level question here. I'm making my first AF project and after a long bout of planning I've finally begun coding. But I'm wondering is there a good way you guys keep track of what you have and haven't implemented, considering that AF isn't that easy to just read through?
(or will it become easy to read through once I get more used to it?)
I thought I would tick through the functionality, but there's a lot to be done per function.
Do you tick off steps on the sequence diagram or something? Or use the # comments for things to come back to? Always build parts in a certain order?
Thinking of my other projects, I just 'know' what's been built, and if I'm unsure I can flick through and have a little read, then if I've missed anything I can pick it up when debugging. (not sure this has been the best approach anyway).
But with AF it feels a lot more cryptic trying to follow the steps through the project and reread the code, and debugging sounds hard enough that I'd like to minimize it by not missing things in the first place. So I'd like to have a good handle on what's been done and what needs to be done. Is this developed in time, or are there strategies you use?
