12-04-2016 03:37 PM - edited 12-04-2016 04:01 PM
Hi
I'm currently trying to get my hands on Actors and plugins, using LV 2016
After having followed the very accurate recipe found here (http://forums.ni.com/t5/LabVIEW-Development-Best/Plug-in-Architecture-using-Packed-Project-Libraries...), I manage to have:
- an "Abstract plugin.lvclass" (inheriting from Actor) in a lvlib in some project. I compiled this .lvlib into a "Abstract plugin.lvlibp"
- a "Concrete plugin.lvclass" (inheriting from "Abstract plugin.lvplib:Abstract plugin.lvclass") in another project. If I right click that "Concrete plugin.lvclass" and hit "New > Vi for override", I keep getting error 1055 (see screenshot)
The only solution is to use the lvlib instead of the lvlibp, i.e. inherit from "Abstract plugin.lvlib:Abstract plugin.lvclass" instead of "Abstract plugin.lvlibp:Abstract plugin.lvclass". In such case, I am able to override Actor Core for example
If I create the Actor Core this way, and switch back to inheriting from the compiled plugin class (lvlipb), The Actor Core gets broken.
What am I doing wrong ? Is there any way for me to build the compiled plugin so that I can still override Actor's methods ? (there is no point in using actors in my case if I can't do that)
12-04-2016 04:39 PM
Followed here, I guess: http://forums.ni.com/ni/board/message?board.id=7301&message.id=691#M691
