Actor Framework Discussions
Extending MGI Example "Basic Panel Actors -> Changing Panels" to dock in the Window
Allen is justACS (or formerly niACS). He has talked a lot about AF on Devcons etc. and also made an unmonitored version of the MGI Panel Manager. (Without Monitored Actors)
And yes, for this particular case, the delay would be ok.
Thanks for the submit.
CLD
Message 11 of 15
(1,069 Views)
FP.Close returning before a front panel is fully closed sounds like a bug in LabVIEW itself rather than this toolkit.  What version of LabVIEW are you using?  I've definitely used FP.Close before Insert VI before without seeing this problem, but in 2020 or earlier.
Message 12 of 15
(1,050 Views)
I used 2024 Q3 32bit.
I believe Bert used 2026.
CLD
Message 13 of 15
(1,043 Views)
Yes, I used 2026- I normally use 2023 but couldn't open your example, so I fired up '26 to try. If I have some time today I'll try backsaving your example to '23 and see if the bug shows up there.
Message 14 of 15
(1,018 Views)
Accepted by fabznx
One additional change has to be made:
In Panel.lvlib:Window.lvclass:Close.vi
we need to replace the FP.Close with the FP.State > Hidden too.
Otherwise, without the Autoshow being set to True, the VI would still not be inserted in the Subpanel.
This works for me.
CLD
Message 15 of 15
(971 Views)
