Actor Framework Discussions
Cluster of AF messages in VIP produce a void wire
In the library, I made a class whose private data contains the message objects - and an accessor that accepts a cluster to write all elements. The cluster makes it into the accessor ok, and the object makes it into the Create.vi - even if I typedef the cluster (which I didn't in this image):
Message 11 of 15
(1,594 Views)
Hello Todd,
I opened the projects you posted on JKI, there was nothing wrong with them when I opened them. Is the wire Void for you?
Joel C
Message 12 of 15
(1,594 Views)
Hello Todd,
When I open this in LabVIEW 2012 I get the following message.
It looks like you are referencing the Actor and Message objects from a user library that was not included in the project. Is this intentional? I do not get the Void wire when I load these classes from the default LabVIEW 2012 directory.
I do not currently have the AF for 2011 installed, but I supsect that might be part of it. It looks like this works properly in 2012. Do you have access to 2012?
Joel C
Message 13 of 15
(1,594 Views)
Yes, that is the void wire, but only after installing the project - not when opening create.vi from the unzipped package file.
Since you don't have AF for 2011 (from here: https://decibel.ni.com/content/docs/DOC-23396), it makes sense that you didn't install the package.
I probably have 2012 around, but I resisted trying that since my customers already have a mix of apps from 2010 and 2011. (My internal "competitor" uses c# and .net, so their exes are tiny and don't even install.) Since AF is available for 2011, I thought it would be okay to stay with that. Guess I'll use the workaround.
Message 14 of 15
(1,594 Views)
I did not include the 2011 AF in the project. VIPM allows one to create a dependency on another project (I have that in the real test project). With VIPM Pro, you can even include the depencencies in a vipc file. I don't have pro, though.
And while 2012 has AF in vi.lib, the 2011 AF package (and the updated and branched packages for 2011 and 2012) install into user.lib.
Message 15 of 15
(1,594 Views)
