Actor Framework Discussions
Actor Core Error Handler - User Defined Warnings?
LabVIEW handles errors and warnings differently. In AF, if I want to create a warning by adding an error code but keep the error flag to false, I don't see how that would ever be handled. The error handler is only called when the error flag is true. Leads me to believe that if I ever want to display or otherwise indicate a warning, I need to set the error flag true and then override error handler method, perform action, and set the flag to false? Is there another way?
(3,787 Views)
You would handle warnings yourself somewhere. Don't propagate them out on the error wire out of your methods. Warnings should either:
a) store them in your actor state that you are now under some sort of warning condition.
b) become a message you send to some other actor to say "I'm unstable, you have been warned."
c) are logged and forgotten
There's no built-in mechanism for escalation of warnings because they aren't errors -- the only correct behavior on a warning as it escalates is to literally do nothing about it. It's a warning, and a warning does require any acknowledgement, by definition.
(3,445 Views)
