01-26-2018 08:41 AM - edited 01-26-2018 08:57 AM
The wizard doesn't follow this path and doesn't give option.
Why?
I don't want to have a fixed concrete msg before starting actore core
I want to inject my concrete msg in event handler
How to do that automatically?
01-26-2018 09:14 AM
Can't you just make a message to set the concrete reply type? The scripting automatically creates a method to set the concrete type. It's like any other method. You could just right click on it and make a message.
If I understand your last post correctly, that should solve your problem.
01-26-2018 09:24 AM
Why?
Because not everyone wants it. My impression is that concrete binding is much more common. I've only injected the concrete child on a few occasions, myself.
As Taggart says, make a message that targets the write accessor for the message implementation.
01-26-2018 09:33 AM
I like the script, but what if you want to send the same message BUT use different actions on the caller?
there is an example here in the forum (see my previous post), a sort of very detailed tutorial about abstract msg.
It creates "addition actor" and "multiply actor".
In the addition he uses injection, which is much superior solution, while keeping the same advantages
It's quite different because it puts the concrete message in another place (not like the script, that puts the concrete in caller's private data).
Also, can you tell me pls what is the meaning and usage of "reference method" ???? In the create abstract msg pop up. Can't find documentation.
01-26-2018 10:29 AM - edited 01-26-2018 10:42 AM
Look at my version.
This implementation is much more superior than the default outcome.
It's so easy to plug-in more behaviours in response to nested actor's reply.
The good news is that I can do it in minutes, all with script help.
The Taggar suggestion worked, it was enough to create another method adding the abstract method as input, then proceed with right click over it, actor framework, create message. In this way the caller actor can set the final behaviour faster, easier and ultimately more secure.
01-26-2018 12:27 PM
You might be interested to know that all those scripting tools for making messages are open, ie. the block diagrams are unlocked and you can edit them. It would be easy to fix. Just take the code that creates the abstract message and then within that call the normal message scripting code with the accessor vi as the input and it will create your message for you.
Checkout the following directories
With those you will almost certainly have all the tools you need.
01-29-2018 01:19 AM
thanks.
to close to topic, can anyone explain what is the meaning of this option "reference method" in the create new abstract msg?
and the path to the method.
When should I use this?
