Academics Discussions
Reply
Generating and Acquiring sin wave using LabVIEW FPGA(USB-7856 Multi-function Reconfigurable I/O Device)
Highlighted
Hi,I am generating sine wave and simultaneously acquiring it while compiling it below mentioned error is getting pop out:
Code Generation Errors
Items with Errors
Unsupported FIFO Method
-FIFO Method Node
-FIFO1 Method Node
The Flush Method is not supported on the current target.Specify another target if you want to flush method,or you can specify another FIFO method.
Here, FIFO use for saving sine wave sample & FIFO1 use for saving cos wave sample.
Can you suggest how to prevent this error.
Message 1 of 1
(530 Views)
