using pressure sensor and optical encoder for measures in a combustion engine
Hello, im using the DAQ pci-6023. Ιn my thesis I have to attach a pressure sensor and an optical encoder and get a diagram showing the pressure as a function of the crankshaft rotation angle. First i want to find out exactly what i need to have on my computer (software , hardware). Secondly i would be grateful if you attached files to help me understand the whole process and making the code.
Note: i have already the sensors, the amplifier and the DAQ
Thanks in advance!!
(2,228 Views)
Have a look if you have access to the sound and vibration toolkit.
The provided examples give a good starting point.
Greetings from Germany
Henrik
LV since v3.1
(2,093 Views)
